Activity Forums Event Videographers Recording presentations – not turning out very good
  • Recording presentations – not turning out very good
    Posted by Ryan Stille on October 7, 2012 at 2:46 am
    I have started recording presentations. I bought a camcorder and a wired mic. I choose a Canon HF10 for its large sensor, external mic input, manual audio controls, and I could afford a used one ($150). But I am not happy how the videos are turning out. Recording a bright projector screen and a dimly lit presenter is difficult. You can see an example here (at the 5 min mark he walks in front of the screen):
    https://www.youtube.com/watch?v=wrU69Eqe8Oc&feature=plcp#t=5m
    The presenter looks good when he is in front of the projector screen, but when he’s not he looks pretty bad. What can I do to improve? Do I need a different camera?
    One thing that bothers me is that the video always looks better in Sony Vegas. When I “render” the video in Vegas, the result is always darker and contrasty. Even when I open the source file in Windows Media Player it seems darker and more contrasty than when I view the file in Vegas. I think I’ve tried almost all the codecs in Vegas. Is there a different one I should be using?
    I am thinking about buying a Panasonic GH-3 next year when the price comes down a little. Would this camera do better?
    Brent Dunn replied 13 years, 10 months ago 3 Members · 3 Replies
  • Mark Suszko
    October 7, 2012 at 11:39 pm
    Ryan, some points in no particular order:
    You can’t expect to use the same iris setting for the screen and the presenter, if they are not lit to the same brightness. You can do four things here:
    Get a second camera that frames only the presenter, with the iris set for him only, then set the first camera’s exposure for just a closeup of the screen, without the presenter.
    Forget showing the screen, Shoot and only expose for the presenter, then add all the slides back in post, from exported JPEGS or TIFFs from Powerpoint.
    Shoot from a more head-on angle and light the presenter while adjusting the light so it doesn’t wash-out the projection screen.
    Stay with the single camera for now, always expose for the speaker, let the screen get blown-out, then add the slides back in during post, but shoot the speaker 99 percent of the time, with some instant re-frames and zooms to change angle in the pauses between paragraphs, during breaths, or at the end of a logical thought.
    You can always go back and add slides later, see, but what you’re there for is to record the *person* first and foremost… humans actually prefer to look at other humans, and you should mostly shoot the speaker in medium shots and facial closeups (allow for hand gestures). This body language is how we communicate, and the graphics come second. You want to put up the slide just long enough to read it and understand it, then get off it and back onto the presenter, who is telling the real story. Otherwise, you’re recording an audiobook:-)
    If you change the framing on the presenter in a regular, systematized way, you will subconsicously make things easier for your audience to follow along. What I mean, for example, is:
    Slide with major section title, full-screen, as the speaker starts talking about it.
    Cut back to speaker in medium wide shot as le leads into his first idea or list of terms.
    Cut to the slide full-screen and hear him read those aloud.
    Cut back to speaker after he’s said whatever is on the screen, but now the shot is closer.
    Cut back to the text screen when he finishes the thought and the new screen has come up.
    repeat.
    Variations:
    To break things up, or provide cover for a zoom transition, cut-away to audience footage you shot in the ten minutes before the presentation started.
    Make a 2-box shot or a picture-in-picture shot of the speaker and the slide together. Don;t dwell on this too long, it is just to hep remind us which slide we were on.
    When someone skims thru this presentation in fast mode, they will see a pattern that makes it easy to find a particular section, because each one starts out the same, like a book chapter, with the text screen by itself, the wide shot for the opening shot, and then more screens with medium shots. The conclusions always end on a closeup, to visually punctuate the speakers’ point.
    Another thought: shooting the text of the powerpoint with a camera as it is projected on the screen, is a very backward way to capture the visual information, and it’s much lower readability and quality, compared to importing the original slide images. Unless there’s a compelling reason like the presenter plays shadow puppeteer with the projection or something, overlapping the screen, there’s little reason to shoot both together. Watch ANY of the TED Talks videos with the sound off and see how they handle graphics and how they choose to shoot the speaker.
    Think about this: most formal speakers will :
    Tell you what they are about to tell you,
    Then Tell you the actual thing,
    Then recap and summarize what they just told you.
    You do not and should not be shooting the same camera angle of the guy doing each of these steps. If you do very ultra-fast zooms to change up your angles at each of these sections, and cut on a breath or a pause, using cut-aways of the slide or audience where necessary, the final edited product can look as if you shot it with a 3-camera live-switch, your audience may stay awake thru most of it, and only you and I know it was done with just one camera.
  • Ryan Stille
    October 11, 2012 at 1:32 am
    Mark, thanks for your comments. I agree, trying to capture the presenter and the slides in the same shot is not the way to do it. I volunteer work basically (but on my own accord), so the only money I have to throw at it is my own extra $$. Hence the single, older camera.
    I like the idea of mixing in the slides in post, although I think that makes a lot more work for me. But most of these presentations are of a technical nature, often without slides. Usually just showing code in an editor and web pages. I agree with what you are saying about capturing the human body language is much more interesting than just the slides, thats why I’ve resisted suggestions to just do a “screencast” of these presentations.
    I think for some of the presentations I may ask the presenter to record their screen, and then blend in that feed later in post. That would work even if they are not using slides.
  • Brent Dunn
    October 11, 2012 at 2:38 pm
    Mark is right on.
    There is also a great program called Camtasia, but it’s not cheap. It lets you capture the screen presentations while you record your voice. You can then have a recording of the computer presentation as a video file as well as your camera shot, giving you two video feeds.
    You can also run a feed from the computer into a video recording deck or switcher and do a live switch edit to a recording deck.
    I would ask them to help out with the funds. You can also rent cameras, switchers, & recording decks.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
