Activity Forums Panasonic Cameras Recording on an AJ HD1400
  • Recording on an AJ HD1400
    Posted by David Braman on March 16, 2007 at 5:51 pm
    We finally got our 1400 in, but the Record Inhibit always stays on, regardless of what the deck switch is set to; regardless of whether the tape protect is on or off; regardless of what tape format I put in. Any idea what might be going on? I hope it’s not a malfunction…we waited months for this thing.
    Arielle Amsalem replied 19 years, 5 months ago 5 Members · 4 Replies
  • Jason Starr
    March 16, 2007 at 10:08 pm
    When I rented an HD1200a I had the same problem. I was tearing my hair out (none left now) but eventually a Panasonic tech support person led me to the obscure menu setting that for some reason I could not find on my own. Try calling Panasonic and they will probably solve it with you.
  • Gary Adcock
    March 17, 2007 at 11:50 am
    [David Braman] “We finally got our 1400 in, but the Record Inhibit always stays on, regardless of what the deck switch is set to; regardless of whether the tape protect is on or off; regardless of what tape format I put in. Any idea what might be going on? “
    OK did you put a tape in?
    Seriously
    what are {both} of you trying to lay off? 1080 or 720?
    the more info on the format, project settings and NLE type and version would help !!!!
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Jeremy Garchow
    March 20, 2007 at 1:59 am
    Are your tapes recorded in LP?
    Check menu number 118 and turn it to off. It’s on by default.
  • Arielle Amsalem
    April 4, 2007 at 12:32 am
    Did you ever figure out how to fix this? I am also working on the Panasonic HD1400 and having the same exact problem. Of course Panasonic technical support closed at 6pm and I’m in a real bind!
