Activity Forums Adobe Audition Recording – mic input into Audition 2014
  • Recording – mic input into Audition 2014
    Posted by Jon Doughtie on October 1, 2015 at 2:54 pm
    Everything I have been able to find in searches is kind of “aged”, so I am asking for feedback on a topic that admittedly has been asked before.
    System specs are in the signature. I will add that we have a BlackMagic Decklink Studio 2 card installed, a legacy from the tape days. We should be able to record analog sound through it from the Mackie 1402. We should. Settings in the BlackMagic app are correct. Yet it is not to be.
    The only success I have had recording directly into audition involves using one of our wireless mic field units,with the receiver plugged into the front panel 3.5mm mic jack. This does work, but is a bit obnoxious to set up.
    I am looking for perhaps a USB mixer that will accept a dynamic mic input (balanced XLR) and work with Audition, maybe even the VO insert in Premiere Pro. A solution that can be permanently installed and simply work.
    Ideas/feedback?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
    Jon Doughtie replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
