Recording Loud Sound
Posted by Richard Kuenneke on March 12, 2014 at 4:19 pmI need to capture the sound of an engine operating, under the hood. Is there a special kind of microphone or other audio recording technique I need to consider to capture sound of a very loud source?
I’m aware of NASCAR and other motor sport productions that feature the sound of the engine accompanying the video we see from behind the wheel. My application is nothing like that – but it’s still very loud.
Thank you!
Rich
John Fishback replied 12 years, 6 months ago 4 Members · 5 Replies -
Ty Ford
March 12, 2014 at 5:01 pmHello Rich and welcome to the Cow Audio Forum.
I suggest a low sensitivity dynamic omni mic like an electrovoice 635a or something similar.
https://www.bhphotovideo.com/c/buy/Handheld/ci/8534/N/4291086007/BI/8631/KBID/9745
Regards,
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford’s Blog -
Ty Ford
March 13, 2014 at 3:47 amRichard,
Sure, just check for he mic with the highest SPL specs.
What sort of car engines are you going to be recording?
Regards,
Ty Ford
Cow Audio Forum LeaderPS: If you have a Sennheiser 421 handy, that should work as well.
Bill Davis
March 13, 2014 at 4:43 amTy mentions two of the best.
My go to stat for mice that work well in high SPL environments is to do a web search on ‘KICK DRUM MICS” – these are usually placed adjacent to (or sometimes INSIDE) the large kick drum in a rock band environment. That creates serious pulse of low frequency pressure as a transient spike. If a mic can handle that – it should handle a car engine without breaking a sweat.
BTW, if you’re not using a device or a mixer with a TRIM control, you may need a pad to drop the level of even a dynamic mic down to match the needs of your recording device input. XLR pads are available from most audio stores including national chains such as Guitar Center.
FWIW.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
John Fishback
March 13, 2014 at 3:09 pmBill is correct. It’s important to realize that every stage through the flow of your audio signal may be clipped (=distorted). So a mic that’s not over-driven by loud sounds might still deliver a signal that’s too loud to the preamp in a mixer or camera. So the preamp stage may distort even if the meter looks good. Putting the pad (basically a kind of volume control) between the mic and preamp lowers the signal to a point where the preamp doesn’t distort. You can buy pads that have switchable amounts of volume cut. BTW, all this is just another reason to always listen to playback.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
