Activity Forums Apple Final Cut Pro Legacy Recording live footage into Final cut pro using a firewire
  • Recording live footage into Final cut pro using a firewire
    Posted by Louie Juarez on October 8, 2009 at 8:47 pm
    I am trying to film with a Sony PD 170 using a firewire cable running into my MacBook Pro so I can have the footage being stored immediately into the program. I have been having a hard time doing it. It keeps saying “device must be in VTR mode when device in enabled” when I press capture now. What does that mean? The camera is on and running fine. what other steps do I need to take?
    Eric Taylor replied 16 years, 8 months ago 6 Members · 6 Replies
  • Mark Suszko
    October 8, 2009 at 9:05 pm
    Try setting control mode within log and capture settings to “uncontrolled device”, then see if it is still seeing a camera picture?
  • Louie Juarez
    October 8, 2009 at 9:11 pm
    Thank you for your response. Sorry I wasn’t being clear enough though. i can see a picture and everything but the problem is I can’t record it for some reason. When I press capture now it keeps saying “device must be in VTR mode when device in enabled.” Then I have to press esc. to get out. Any advice is very much aprecaited, Thanks agian.
  • Nate Stephens
    October 8, 2009 at 10:50 pm
    Make sure your camera is on free run time code. Final Cut pro is looking for Time code..
    It works very well with our HVX200.. Recorded over 36 hours once to a hard drive with no drop outs or other problems except FC doesn’t recognize quicktimes over 12 hours long.. So it would not open in FC. But it played back in the QT player.
    FCP, Mac Pro, Mac Book Pro, HPX500, HVX200, Betacam, Dvcam
    Write for the Edit, Shoot for the Edit, Edit…..KISS Principle
  • Michael Sacci
    October 9, 2009 at 12:17 am
    You have to do want Mark said, Device control needs to be “Non-controlible” to capture live.
  • Rafael Amador
    October 9, 2009 at 3:39 am
    [Nate Stephens] “Make sure your camera is on free run time code. Final Cut pro is looking for Time code.. “
    This makes no sense at all. Free Run TC is used by the camera on recording. Even for recording is almost a no-no: You will have a jump in your TC whenever rec/stop.
    rafael
    http://www.nagavideo.com
  • Eric Taylor
    December 20, 2009 at 4:57 pm
    Please share with me the info On how I can record HD live footage from my HVX200 into FCP 6.06
    Thanks Eric
