Activity › Forums › Boris FX Particle Illusion › Recording issues
Recording issues
Posted by Leonard Rivera on August 7, 2008 at 4:46 amEvery time I try to record (export video) I get this error –
“Can’t connect ImageOutPin to FileInPin”
No matter what format or codec I choose. Please help.
Alan Lorence replied 18 years ago 2 Members · 19 Replies -
Leonard Rivera
August 7, 2008 at 4:49 amI’m running Vista 64 on a Phenom X4 2.5Ghz with 4 GBS ram and an ATI HD 3450 PCIe
Alan Lorence
August 7, 2008 at 2:44 pmIs this with a background image/movie loaded?
Try this: create a new project, 640×480. No emitters, no background image/movie. Click “Save Output”, save as AVI, select any codec you normally use.
Also try:
– WMV
– restarting the computer
– Download “Lagarith” or “Huffyuv” codecs and try those.Alan.
Leonard Rivera
August 7, 2008 at 4:00 pmOK your test worked fine.
Yes I had a background image. Here’s my work flow.
I have a huge image in photoshop. I’m using it for a game using gamemaker7. I want to use PI to create flames for torches and stuff. Basically want to take PI’s output (wish it could do animated gifs) – convert to animated gif, import to gamemaker, create sprite from animated gif and use.
So in Photoshop, I’m cropping out just the small pieces I need. I bring those in to PI as backgrounds, setup the animation and attempt to render.
I think the issue is the non-standard pixel x pixel sizes and aspect reations of the cropped images I am using. I know many vieo codecs will not support it. I was hoping I cound exprt as PSD and construct the gif that way but I stick get the same issue.
I would prefer the ability to export firectly to animated gif, but I can convert many movie formats to AG as this is not the hard part. I just need to figure out how to get past this issue. I’m kind of working on another part of our game so I left this alone until I heard back.
Would you suggest I crop my images to 640×480 for backgrounds to import?
Alan Lorence
August 7, 2008 at 4:08 pmSome codecs don’t like weird sizes — you’re probably better off saving an image sequence out of pIllusion, not a movie.
Alan.
Leonard Rivera
August 7, 2008 at 4:43 pmI’m trying PSD, BMP etc.. But now I’m getting
“Can’t find acceptable pixel format”
Alan Lorence
August 7, 2008 at 5:10 pmMake sure your desktop is set to 24 or 32 bpp color.
Also try restarting the computer.
You may need to update your video drivers too.
Alan.
Alan Lorence
August 7, 2008 at 5:29 pmOk, then I guess the answer is: make sure the output size (stage size) is not a weird number. Make sure it’s divisible evenly by 4 and you should be fine.
Alan.
Leonard Rivera
August 7, 2008 at 5:53 pmOK. Will do. I’d bet that solves it…but I don’t gamble.
I’ll let you know.
Leonard Rivera
August 7, 2008 at 6:01 pmNope. I get the same pixel format error and when I click OK it says “Can’t Create OpenGL context”
This was trying to do AVI no compression. I’m going to try PSD again, if I get the same error, I’m going to take a closer look at my video card’s opengl settings. In the meantime, If you want me to send you the project and files (background), email me at my FirstInitialLastName at digital-church.com.
I tried setting the stage size to a standard resolution from the project settings drop down that was slightly higher than my background.
