Activity › Forums › VEGAS Pro › recording glitch with Sony AFX53 camcorder
  • recording glitch with Sony AFX53 camcorder
    Posted by Kevin Mccarthy on May 24, 2019 at 6:23 pm
    I realize this is probably not the place to ask, but I can find nothing anywhere else.
    When I record long meetings etc. on my AFX53, I find that I have a drop-out of 1 or 2 frames every 30 minutes or so when I import the video to Vegas pro. I am recording at 1080 HD. Any suggestions?
    Thanks in advance
    Kevin
    Ole Kristiansen replied 7 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • George Dean
    May 24, 2019 at 11:56 pm
    Hi Kevin,
    Are you matching your Project Settings to your source media from the Sony?
    Best Regards……George
  • Kevin Mccarthy
    May 25, 2019 at 1:07 am
    Yes, Always
  • Francois Pénzes
    May 25, 2019 at 2:08 am
    Hi Kevin
    I’ve seen some instances where the ingesting machine’s CPU gets overtaxed and has momentary ”hiccups”. Could we get the details on your gear ?
    Cheers ?
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Ole Kristiansen
    May 25, 2019 at 6:37 am
    Hi
    Are we talking about your camera regarding the FAT32 file system only supports files up 4GB in size?
    Don’t think Vegas can clip-spanning – as you can in Adobe Premiere! Maybe your camera came with a program – where you can put long recordings together without losing your picture and sound!
    Best,
    Ole
  • Eric Clinch
    May 25, 2019 at 7:34 am
    Doesn’t using Device Explorer to import the clips stitch them?
  • George Dean
    May 25, 2019 at 1:44 pm
    Hi Eric,
    I’m out of my element with the Sony file size restriction, but I have read user having a problem stitching their files together and ultimately used Sony Playmemories (I think that is the name of it) to solve their issue. May be worth a test.
  • Kevin Mccarthy
    May 25, 2019 at 4:49 pm
    I do believe my problem stems from a file size limitation, as when I import them, the clips all seem to be approx the same length and size. I looked at the Sony program mentioned and didn’t see any mention of my problem. I guess I could capture the last frame of a clip and the first frame of the next clip to fill the gap. Does anyone have any other alternative? Thanks in advance.
  • Ole Kristiansen
    May 25, 2019 at 5:50 pm
    As George has already mentioned – use the Sony Playmemories Home app – which will show your footage as one big clip – then you can save the whole clip and use in for example Vegas!
    Best,
    Ole
