Activity › Forums › AJA Video Systems › Recording from Cable Box via HDMI or component.
  • Recording from Cable Box via HDMI or component.
    Posted by Jeff Taylor on December 28, 2011 at 1:55 am
    I am attempting to record a signal from a comcast HD box. I have tried HDMI and component hookups with no luck. I did change the input to HDMI and component respectivley as well as the output. I have been unable to determine if it is even possible to record a cable signal onto the deck.
    If anyone can give me some ideas and suggestions, it would be appriciated.
    With regards,
    Jeff Taylor
    Gary Adcock replied 14 years, 9 months ago 3 Members · 4 Replies
  • Gary Adcock
    December 28, 2011 at 5:02 am
    Sorry,
    Aja adheres to the HDMI spec that includes digital copy protection, that is the reason you cannot get it to work.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Jeff Taylor
    December 28, 2011 at 4:59 pm
    Thank you for your response. I thought that might be the case but wanted to make sure. Have a great day.
  • Rodrigo Allendes-fernandez
    December 29, 2011 at 10:59 pm
    Gary,
    And what if I transform the signal passing through some converters? HDMI -> SDI, and (if no work) with another SDI -> HDMI converter?
    Like I find a solution for Canon 5d Video Assist. Hdmi signal from camera, connected to a hdmi splitter (one for onboard monitoring; and the other for a HDMI-> SDI converter). Then I get a 480i signal, but in KiPro appears 525i. Otherwise, or without the splitter, signal jumps between Livemode and Reccording.
    So, modifing the signal passing by several converters, will do eliminate the copy protection?
    Rodrigo Allendes-Fernandez
    Video Assist Operator
  • Gary Adcock
    January 4, 2012 at 3:49 pm
    [Rodrigo Allendes-Fernandez] “So, modifing the signal passing by several converters, will do eliminate the copy protection?”
    there is no copy protection in an analog video signal.
    gary adcock
    Studio37
    Chicago, IL
