Activity › Forums › Panasonic Cameras › Recording formats information needed
  • Recording formats information needed
    Posted by Bruce Klein on September 25, 2013 at 3:16 pm
    I have a shoot tomorrow for a station that requires the following parameters…
    HD Content absolute requirements
    Resolution : 1280 x 720 PROFRESSIVE
    FRAME RATE : 59.94 fps
    CONSTANT Bit rates
    48 KHZ audio Sampling
    PCM audio
    Accepted HD types:
    DVC PRO HD: 100Mb/s, 4:2.2
    XDCAM-HD: 50 Mb/s 4:2.2
    MPEG2 (long GOP:IPB), 50 MB/s, 4:2.2
    I just want to know what setting I should set my 170 camera on…
    I am asking so I can be sure and assured that I select the proper Format…
    The second camera on the shoot is a Sony AVCHD format and I believe I could use some info for that cameras setting.
    Post will be on Premiere pro cs5.5 and my question there is canI post these formats at the same time on the same timeline… That question is probably for a different forum…
    Thanks in Advance for your assistance…
    I use Adobe Premiere Pro CS 5.5 on a IMAC 27, Intel core i5 2.7 GHz, 12 GB 1333 MHz DDR3… MAC OSX 10.6.8 I have a 2 2 Terabyte external drives also.
    Thanks in advance for your help.
    Bruce
    Matthew Sonnenfeld replied 13 years ago 3 Members · 2 Replies
  • Chris Tompkins
    September 25, 2013 at 9:37 pm
    You want the 720p/60p setting on the 170
    Chris
  • Matthew Sonnenfeld
    October 1, 2013 at 10:05 pm
    you shouldn’t have any problems handling those materials together in Premiere. Set the Sony to 720/60P if available, otherwise shoot 1080/60P if available and scale footage down in the Premiere timeline. If 60P is unavailable shoot 720/30P or 1080/30p if 720 is unavailable and put that in the timeline. Export the timeline at the deliverable spec once completed.
    Co-President at fourB Productions, Inc.
    Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
    AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
    Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3
