Activity Forums Panasonic Cameras Recording audio w/ no video?
  • Recording audio w/ no video?
    Posted by Lars Wikstrom on June 13, 2006 at 6:40 pm
    Can I do that? Tongiht I need to get some voice overs and my VO person can’t come to the house. I have used the HVX with a small XLR shot gun with great results to do VO’s but it lays the video down with it. Is there a way to only do VO’s with out recording the video?
    -Lars
    Noah Kadner replied 20 years, 3 months ago 4 Members · 6 Replies
  • Jeff Carson
    June 13, 2006 at 7:27 pm
    I do that by recording to Mini-DV tape… (but never with the camera mic of course)
  • Jeff Carson
    June 13, 2006 at 7:28 pm
    …meaning that you can capture to your edit system as audio only…
  • Lars Wikstrom
    June 13, 2006 at 7:57 pm
    Ahhh, ok so there is no way to record only voice to the P2 card. I’ve had the camera about a month now and I haven’t even opened the Mini DV casset area on the camera.
    -Lars
  • Frank Nolan
    June 13, 2006 at 8:07 pm
    Regardless of whether you use the P2 card or the mini dv tape you are still going to record video. It is a video camera with audio recording capabilities as well. It is not a stand alone audio recorder. If you want to use the P2 card for the VO’s just set the video portion to DV so you can get more recording time.
  • Lars Wikstrom
    June 13, 2006 at 9:05 pm
    That is what I have been doing by setting it to DV mode. But since I saw the camera had Audio dubbing ability I thought that I would toss out that question to see if I was missing something.
    Thanks anyways.
    -Lars
  • Noah Kadner
    June 13, 2006 at 9:20 pm
    Maybe you should consider adding a seperate audio recording device to your kit bag. You can get direct to computer recording interfaces for under $500 these days. The HVX can be used as an audio recorder although you’re wasting an incredibly high quality and expensive HD camera in the process.
    Noah
