Activity › Forums › Panasonic Cameras › Recording
Recording
Posted by Brad Williams on May 7, 2011 at 1:34 amDoes anyone know if it is possible to record from the Panasonic HPX300 to a Firestore FS-4 Pro Hd recorder? I am sure it would be better to record to the P2 card.
Steve Eisen replied 15 years, 3 months ago 4 Members · 9 Replies -
Chris Tompkins
May 7, 2011 at 3:21 pmSure. FW port out to the FS recorder.
It is MUCH better (reliable) to use P2 Cards instead.
That has been our experience as well as others I have read here.
Chris Tompkins
Video Atlanta LLC -
Brad Williams
May 7, 2011 at 5:09 pmI have tried to do that. It will not record. I set it just like the Panasonic specified with no luck. It is set onDVCPRO HD/60i.
Chris Tompkins
May 7, 2011 at 5:10 pmoutput via IEEE 1394 is not available when the AVC-Intra codec is selected.
Chris Tompkins
Video Atlanta LLC -
Brad Williams
May 7, 2011 at 5:28 pmI have 1394 control but it is not recording from the camera to the FS-4
Brad Williams
May 7, 2011 at 7:03 pmAnyone else have any ideas? Coming from my Sony EX-3 it works fine.
Jim Carswell
May 7, 2011 at 8:28 pmTo work with your camera you need to Firestore FS-100 not the FS-4.
JimJim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com -
Steve Eisen
May 9, 2011 at 4:09 pmFS-4HD is for HDV cameras.
It will record DV for you not HD.
The FS-100 is for Panasonic DVCProHD cameras
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
