Activity › Forums › Apple Final Cut Pro Legacy › Record Scrubber in FCP
  • Record Scrubber in FCP
    Posted by Dikser on May 11, 2006 at 6:28 pm
    Hello again,
    Does anybody know a method to record the scrubber action in FCP to tape?
    I can produce a nice effect by dragging the scrubber over a clip at various speeds, forward and backward etc, and was wondering if there’s a way to capture that live to tape, if that makes sense.
    Thanks for any advice anyone might have,
    Kevin Monahan replied 20 years, 4 months ago 5 Members · 6 Replies
  • Just put a tape in the deck, hit record, and scrub away.
  • Dikser
    May 11, 2006 at 10:30 pm
    To get a signal out wouldnt I need to be in print or edit to tape mode? And in those modes I don’t have access to the scrubber. What am I missing here?
    Thanks for your time.
  • Debe
    May 11, 2006 at 10:41 pm
    If you have View>External>All Frames set, you should be getting your output on your external audio and video monitors at all times via the FW port, which is really the best way to work, anyway.
    debe
  • Bret Williams
    May 12, 2006 at 5:04 am
    If ya can see it on your NTSC monitor, then you can record it. No you don’t need to print to tape or edit to tape. Many people don’t bother. Print to tape just makes sure everything is mixed down and rendered and halts other processes to give full attention to output in hopes of not dropping frames. Edit to tape is similar, but with deck control.
  • Dikser
    May 12, 2006 at 12:30 pm
    Thanks people,
    It was the View/All Frames thing.
    Thanks again.
  • Kevin Monahan
    May 12, 2006 at 7:21 pm
    This goofy technique is actually listed in my book. Go figger! 😉
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
