Activity › Forums › Blackmagic Cameras › Record / pause PROBLEM!
  • Record / pause PROBLEM!
    Posted by Ali Quintana on October 27, 2013 at 6:03 pm
    Some how my Pause (REC) button is not working, I remember it always
    worked.
    I use to record, then press rec again to pause and rec again to continue
    recording. This would mean that the files would continue in one folder. and when I press play it would play it as one go.
    All of a sudden when I click rec to pause and continue, it registers the next recording as a separate file.
    I did update some weeks ago but cant remember if it started right after that, I just noticed it yesterday.
    Any one with the same problem?
    Matthew Sonnenfeld replied 12 years, 11 months ago 2 Members · 3 Replies
  • Matthew Sonnenfeld
    October 30, 2013 at 7:02 pm
    As in it would play it continuously on the camera in an NLE it would come up as one clip with markers?
    Co-President at fourB Productions, Inc.
    Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
    AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
    Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3
  • Ali Quintana
    November 2, 2013 at 8:13 pm
    Thank you, but I dont really understand your response. Sory about that.
    I mean that I thought when u film and click rec again, it pauses, so if
    you click again it will continue recording. This so afterwards you get everything in one file. If you press stop and the rec again you have the dngs in different files.
    My problem is that I can not seem to pause (using the rec) it does pause but still creates a new file when i click rec to contimue.
    November 7, 2013 at 5:57 pm
    I’m not sure if I fully understand what it is that you are trying to do.
    If I understand you correctly, you’re trying to record a single clip though you want to use a Pause/Rec button to have multiple “takes” (for lack of a better word), within a single “clip”?
    Are you recording raw or ProRes?
    To be honest, I don’t think I’ve ever seen it when a Pause/Rec saves it as one clip. The Pause/Rec button by my understanding is just terminology but it is a synonym for a Start/Stop button which is how it’s labeled on many other cameras, notably Sony cameras.
    Can you please elaborate on why you need this type of workflow? Maybe there’s another type of workaround that can be figured out.
