Activity › Forums › Apple Final Cut Pro Legacy › Record inhibit on D5 deck
  • Record inhibit on D5 deck
    Posted by Phil Yunker on May 13, 2008 at 12:01 am
    Trying to record to a Panansonic D5 deck / hd – 3700B with a maxell tape and I’m getting the record inhibit light coming on. First time with this deck, please help, tight deadline.
    Thanks.
    PHIL
    Phil Yunker replied 18 years, 4 months ago 6 Members · 9 Replies
  • 9 Replies
  • David Roth weiss
    May 13, 2008 at 12:09 am
    Are you using a used tape, or a tape that has the record inhibit button moved to the inhibit position?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Phil Yunker
    May 13, 2008 at 12:13 am
    it’s a new tape. are the A and B red buttons the rec inhibit buttons? they have been popped up
    PHIL
  • David Roth weiss
    May 13, 2008 at 12:38 am
    Phil,
    I honestly can’t remember, its been a while. Sorry, I hope someone else can jump in.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Phil Yunker
    May 13, 2008 at 12:49 am
    DRW,
    Thanks for the try.
    Anyone?! I have tried two tapes, one wit the red a / b tapes popped up and the other down. are these the rec. inhibit tabs? is there something in the decks menu that releases’s the tapes or does it by software?
  • Jeremy Garchow
    May 13, 2008 at 1:23 am
    Another guess here, but I know on other Panasonic decks you can enable Rec inhibit form within the menus. Crack open that manual and find out which one it is.
    Jeremy
  • Eric Pautsch
    May 13, 2008 at 1:38 am
    Popped up means they are record inhibited. Also check the menu settings.
  • Rennie Klymyk
    May 13, 2008 at 5:02 am
    the record (A+B) tabs must be down. Also the “C” tab (in the center by the window) is up for 4 track audio and down for 8 track.
    You must go to the “HOME” menu and set F13 to recording enabled.
    “thou can not stir a flower without crumbling a star” ……Henry Wadsworth Longfellow
  • Gary Adcock
    May 13, 2008 at 12:57 pm
    [eric pautsch] “Popped up means they are record inhibited. Also check the menu settings. “
    correct- also check the tape, some b-stock tapes will not work in the D5 it is pretty fussy when it comes to tape stock IMHO.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Phil Yunker
    May 14, 2008 at 3:10 pm
    Thanks all. that solves some of the issues. Also, the client had got a bad deck from the rental house (kept shutting off, even while playing a tape) this was the main issue (the bad deck from rental house) Client also had a bad Kona card, AJA was very helpful.
