Activity › Forums › Panasonic Cameras › Record in HD while outputting SD-SDI?
  • Record in HD while outputting SD-SDI?
    Posted by Jonathan Lang on November 8, 2013 at 5:48 pm
    I’m working with a HPX171E – I’m sure this is possible, but I just can’t seem to find the right settings.
    Our BNC cables can’t reliably transmit HD-SDI (I know… they’ll be replaced soon) and so I want to send an SD-SDI signal while still recording in 720p on my P2 cards.
    How can I activate the downconvert for the SD-SDI while I’m recording HD?
    Chris Tompkins replied 12 years, 10 months ago 2 Members · 3 Replies
  • Chris Tompkins
    November 10, 2013 at 12:42 pm
    Page 107 of the manual will show you the Down-Convert options.
    Switches down-conversion output mode.
    SIDE CROP: Crops the right and left edges of the images with the 4:3 aspect ratio.
    LETTER BOX: Adds black bands at the top and bottom of the images, and the images with the 16:9 aspect ratio are displayed in the 4:3 aspect ratio.
    SQUEEZE: Select this option for 16:9 aspect ratio images. When viewed on a 4:3 aspect ratio monitor, images are squeezed horizontally.
    Your shooting 720p and you want to output 720p? This is not a down convert.
    Chris
  • Jonathan Lang
    November 10, 2013 at 3:11 pm
    As I stated, I want to output SD-SDI – I looked at the manual first of course… what I didn’t explicitly get out of it is that the down-convert only activates when you’re recording in an interlaced format. So if I’m recording at 1080i, down-convert is possible for the SDI-Output – no luck with a progressive format like 720p.
    So that’s what I did, set my cameras to 1080i instead of 720p: voila! 576i over SDI and HD on my P2 cards! 🙂
    Student of audio- & video-engineering at the IMM Düsseldorf in Germany.
  • Chris Tompkins
    November 10, 2013 at 5:05 pm
    I’m sorry, I misunderstood, glad you made it work.
    Chris
