Activity Forums Apple Motion Record button doesn’t seem to be working properly
  • Record button doesn’t seem to be working properly
    Posted by Roli Rivelino on April 2, 2010 at 5:46 pm
    I’m following a motion tutorial and it just doesn’t seem to work properly, it’s obviously user error but I can’t work it out and I’ve tried like ten times already.
    My workflow:
    Open up exercise file map and mini car > select mini layer > turn on record > move car slightly to get red triangle > position play head at 2 seconds > move car to Texas >
    The problem comes when I try and set another keyframe at 4 seconds and move the car to California, instead of getting another red line pointing away from Texas, the red line just moves and I simply move the first keyframe to 4 seconds.
    I’ve experimented with turning record on and off at varying points this sort of works but I don’t really feel in control
    What am I doing wrong please?
    PS I’m about to watch the manual keyframe tutorial which I’m sure sorts this problem, but I’d like to know what I’m doing wrong for this one.
    many thanks
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 16 years, 5 months ago 2 Members · 2 Replies
  • Mark Spencer
    April 2, 2010 at 6:13 pm
    When you drag the car make sure you don’t drag from the little X in the center – click anywhere inside to bounding box except on the center (which selects the keyframe of the motion path).
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Roli Rivelino
    April 2, 2010 at 6:32 pm
    Ah simple, sew hair back into scalp 🙂
    Thank you
    System
    8Gb RAM
    Equipment
    Firestore FS-100
