Activity Forums Apple Final Cut Pro Legacy Reconnecting Media Question
  • Reconnecting Media Question
    Posted by Russell Hill on April 7, 2005 at 5:40 pm
    Can some one help me with this small problem? I have inherited a FCP project from another worker and it is huge. The thing is that he had poor media management skills and there is media everywhere. I have tried to find it all and moved it to one location. Now all of the media needs to be reconnected. My question is
    Ed Dooley replied 21 years, 5 months ago 4 Members · 3 Replies
  • David Bogie
    April 7, 2005 at 6:10 pm
    It would have been better to have used Media Manager to create a copy of your project and all associated media but you would have needed adequate storage to make all of the copies.
    Read the section in the manuals on reconnecting, it’s pretty easy to do. Once you locate one file, you have the option to reconnect everything in that path.
    However, if you have moved your media by copying it and then deleting the originals, some of it will never reconnect and you will have to reimport it. I doubt any of your renders will reconnect (mine rarely do) but you could get lucky.
    bogiesan
  • Steve Eisen
    April 7, 2005 at 7:10 pm
    If the media is all in one location, then reconnect your media, select files manually and make sure Reconnect All Files in Relative Path is selected.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 1.65 TB External Stor
  • Ed Dooley
    April 7, 2005 at 7:50 pm
    Have you tried closing out of FCP, then reopening it? Whenever I move stuff around, the next time I open FCP I get a message saying, er…. I forget what it says, but the gist is “the media is moved or offline, do you want to reconnect it?” In my case it’s usually because I deleted a file intentionally, so I don’t choose reconnect. Just a thought.
    Ed
