Activity › Forums › Apple Final Cut Pro Legacy › Reconnecting Media – one clip at a time
  • Andy Lancaster
    July 27, 2008 at 8:34 pm
    im having the same problem
  • Eric Hansen
    July 27, 2008 at 9:00 pm
    i am currently working at 3 different facilities. i have not encountered this problem in awhile. all the facilities are currently at FCP 6.0.3 and various versions of Quicktime. i had suspected at the time that the problem may have been the version of Quicktime, either 7.4 or 7.4.1 that changed the way the clips were read by Final Cut. at that one particular facility we recaptured the footage so it was in a newer version of QT and that seemed to work. in the other facilities that i am at, all processes from logging to capture to edit are being done on the same version of Quicktime and on Final Cut 6.0.3. i so don’t know if Apple fixed the problem in newer versions of QT or FCP or not.
    i know thats not an answer, but i can tell you that i have not had this problem since about a month after my last post. at that point all the old problematic QT files had been recaptured (unpaid interns rock!) and the old FCP log files were resaved in FCP 6.0.3. so my advice is to get to the current versions of QT and FCP and see if you’re still having reconnect issues. otherwise you may have to recapture as we did.
    e
    4 G5s, OSx 10.4.11, Final Cut 6.0.2, Kona LH (v5.1)
    Xsan: Xserve 2.0 G5, 3GB RAM, 2 7TB Xserve RAIDs, Sanbox 5200
    Quantum SDLT600A
    decks: Sony HDW-M2000/10 HDCAM, HVR-M10U HDV with HD-Connect, DSR-1500 DVCAM, UVW-1800 BetacamSP
    MacBook Pro: 2.33, 2GB RAM, OSx 10.4.11, Final Cut 6.0.2
    cameras: Panasonic HVX200, Sony FX1 and A1U, Arri S/B 16mm
    skis: Volkl Gotama 183s with 914s and Lange Fluid 120 boots
  • Joseph Donnelly
    September 16, 2008 at 12:05 am
    I’ve had the same problem, though with .aif files mostly. Another work around, rather than recapturing material, is to import the problem files into FCP and re-export them to the same format and file name using the export queue. Once you do that, everything should reconnect via the relative path.
  • Tal Amiran
    October 14, 2013 at 2:27 pm
    I had the same problem and what I did was to simply restart my computer. I haven’t changed anything and it just went back to re linking all the clips which were highlighted in my browser for re connection.
    I appreciate it might not always be the solution but it did work for me.
Page 2 of 2
