Activity › Forums › Apple Final Cut Pro Legacy › Reconnecting Media (HD)
  • Reconnecting Media (HD)
    Posted by Ali Cotterill on February 13, 2008 at 11:08 pm
    I’m trying to reconnect HD footage. I shot on the HVX, imported off P2 cards and have been getting the footage into Final Cut 6 via Log and Transfer. My drive got disconnected and the reconnect media function that works with DV footage won’t work. The Final Cut Manual is not so helpful. What’s the solution to this? -Ali
    Ali Cotterill replied 18 years, 7 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    February 14, 2008 at 2:29 pm
    If you changed the clip names from the original media file names, things get dicey, is that what’s happened? Otherwise it should be working without a hitch.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ali Cotterill
    February 14, 2008 at 11:22 pm
    I didn’t change any masters clips, I subclipped everything. I shutdown everything and restarted and the clips were reconnected. But for future reference, how do you reconnect because the audio and video are in separate folders and the video is .mxf files whereas the reconnect media function is looking for .mov files. -Ali
