Activity › Forums › Apple Final Cut Pro Legacy › Reconnecting media from Motion Jpeg to Blackmagic 10 bit
Posted by Daniel Garcia robles on November 23, 2005 at 12:20 pmI captured with uncompressed Blackmagic 10 bit, then created Motion JPEG media to edit on laptop. After editing I copy the FCP file into the Uncompressed system and even when I reconnect to the uncompressed files and create an uncompressed timeline matching the settings of the footage I still need to render!!! Also, after rendering the quality of the footage suffers as it seems to soften…what am I doing wrong? I have done this before and always worked…
Any help appreciated…Daniel
Daniel Garcia robles replied 20 years, 9 months ago 5 Members · 10 Replies -
Jerry Hofmann
November 23, 2005 at 1:30 pmTry using the media manager to create that offline sequence on the Laptop… select make offline for the duplicated sequence, set it to match the original captured files, and reconnect that copy to the uncompressed media.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
November 23, 2005 at 4:19 pmHi Jerry,
thanks for the comment, but your method is actually erroneous. If you do that, what happens is, you are working on a sequence which was customised to work with offline quality footage, therefore, when you reconnect the footage (after you make it offline), you will have uncompressed footage in a sequence that was meant for offline, needing to render as a consequence. The problem here is that, even when I create a sequence to match the settings of uncompressed footage, FCP stills needs to render (that is even when footage and sequence settings match!)…I wonder if there is something hidden which I have overlooked, but I have extensively searched and everything seems to be in order so I do not know what this still happens…
I appreciate your help! : )
I wonder if anyone else has come up with a problem like this before…Daniel
Todd Beabout
November 23, 2005 at 4:27 pmOne thing you could try would be to start a new sequence (Uncompressed 10-bit as your “Easy Setup”) and then copy paste your entire sequence from the old into the new sequence. See if that has any effect.
-Todd Beabout
Vazda Studios -
November 23, 2005 at 4:57 pmThanks Todd,
Actually, for me to be able to get the uncompressed footage from the offline sequence I have no other choice but copying it and pasting it to another sequence with the right settings (matching format etc)…but it doesn’t work for some strange reason, that is my problem here.
Thanks so much for your help…still no idea what can be causing this…Daniel
John Christie
November 23, 2005 at 5:12 pm -
Sean Oneil
November 23, 2005 at 6:52 pmDaniel, I understand you think the new sequence settings matches the settings of the reconnected clips. It does not. If it did, you would not have to render. It’s that simple.
I’m fairly certain that your clips have Motion attributes applied to them because they were altered to match the frame size for your offline P-JPEG work.
You need to open up one of the clips and go into the Motion tab. Make sure scale, center, and anchor point are set to zero. Now click the triangle next to “Distort”. Make sure “Aspect Ratio” is set to zero as well.
If any of these are not zero, you need to select all of the clips in the sequence, ctrl-click, and select “Remove Attributes”. Then check the appropriate boxes.
Todd Beabout
November 23, 2005 at 7:08 pmAnother easy way to do this (rather than putting each clip into the canvas) would be to select all the clips in your timeline, right-click and select “Remove Attributes”. Then select “Basic Motion” and “Distort” to reset all the clips at once.
Post back if this was your problem.
-Todd Beabout
Vazda Studios -
November 29, 2005 at 9:37 amThanks for your help John, yes, you were right, there was a change in aspect ration applied to the footage…something I wasn’t aware of…so, that is the mistery solved!! I will have to remember to change the aspect ratio every time I replace the footage! Cheers!
Daniel
November 29, 2005 at 9:44 amThank you so much for your help Sean, as I said when replying to John, you were right, my aspect ratio settings had been modified when creating the new low-res project but I couldn’t understand why because what I normaly do is to export on Motion Jpeg at 750×576 so, the aspect ratio should be the same when reconnecting the footage…anyway, it seems pretty easy to fix by removing all motion attributes applied to the clips on the timeline…so, will have to remember that next time! Cheers!!
Daniel
November 29, 2005 at 9:45 amThank you Todd, that is a very good trick, specially now that I know that was my problem!!!
CheersDaniel
