Activity Forums Apple Final Cut Pro Legacy Reconnecting Media
  • Reconnecting Media
    Posted by Chris Guevarra on May 14, 2010 at 4:19 am
    Hi all,
    So I’m having a huge problem that I’m sure lots of people have ran into and (hopefully) have the solution to solving…
    I recently just duplicated all my media source files (about 290 hours of footage) from a number of hard drives to another a bigger 3TB HD for the purpose of having multiple editors working on the film at the same time.
    I’ve already spent a number of months working on a cut that the new editors can add to once they jump on board. But here’s the problem:
    I’m using Final Cut 5 (never upgraded and definitely won’t in the middle of this project) and once I tried to RECONNECT the duplicate files from the new 3TB HD, onto the same FCP project file (a test copy of it) that has all the cuts I’ve been working on, this message pops up:
    “Some attributes of one or more of the files you have chosen do not match the attributes of the original. This may cause problems within the sequences that are dependent on them. The attributes that differed are as follows:
    – Media Start and End”
    Upon successfully reconnecting the media, this scary message pops up:
    “One or more files did not have enough media to reconnect some clips. Some edited clip items have had their out point adjusted.”
    After which, I go into the timeline to see if anything has adjusted and there definitely has been a HUGE, noticeable difference
    Chris Guevarra
    massmovementtv.blogspot.com
    Chris Guevarra replied 16 years, 4 months ago 2 Members · 2 Replies
  • Shane Ross
    May 14, 2010 at 4:59 am
    You asked this…5 days ago. Mark answered you. Do you have any response to his questions?
    https://forums.creativecow.net/thread/8/1086084
    From my experience, he is right on. If you didn’t name your clips as you captured, if they are all UNTITLED-1, UNTITLED-2…and multiple clips with that naming convention, you will run into serious issues reconnecting.
    Shane
  • Chris Guevarra
    May 14, 2010 at 5:31 am
    Whoops! Sorry about that. I don’t think I meant to repost this. For some reason it popped up when I wanted to add a new post and so I just pressed the button without thinking about it.
    I’ve been out of the editing office for the week so I havne’t been able to try and reconnect the clips individually but your ideas sound about right. Once I test it, I’ll let you all know. Thanks again for the feedback!
    -Chris
    Chris Guevarra
