Activity › Forums › Adobe Premiere Pro › Reconnecting lost media
  • Reconnecting lost media
    Posted by David Thorne on February 10, 2012 at 5:57 pm
    Hi guys I was wondering if anyone could help.
    I have a premier pro project recovered along with ALL the files used in the edit prior to a hard drive failure.
    When I open the project Premier pro asks me to find each and every file (which I have saved) I sat there for nearly an hour recollecting each file before giving up – is there a faster way of reconnecting all the files in on go or batches?
    Dave
    David Thorne replied 14 years, 7 months ago 2 Members · 2 Replies
  • Petros Kolyvas
    February 10, 2012 at 6:27 pm
    Select all the items in the bin then, under the project menu select “Link media” and once it finds one it will try to find the rest based on the original relative paths and is generally quite good if the organization of the clips stayed the same.
    You can select as many clips as you want at once, or all of them.
    Hope that helps!
    PK
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • David Thorne
    February 10, 2012 at 7:13 pm
    It worked like a charm – thank you!
