Activity Forums Apple Final Cut Pro Legacy Reconnecting Issues with Batch list
  • Reconnecting Issues with Batch list
    Posted by Smith Glover on February 12, 2011 at 8:24 pm
    Hello,
    I am working with a client who created a ton of sub-clips and sent me a batch list of them. He is using FCP 7.0.3 and I am using 6.0.6. When imported, all of the subclips show up with the same name in the browser window (not sure if this is standard as I haven’t used batch lists before).
    I am having two issues:
    – Since there are a ton of subclips, I am obviously hoping to reconnect all of them at once. However, when I go to reconnect, even though I highlight all the clips in the browser window and have checked off the “reconnect all files in similar path” box- it will only reconnect one sublicip at a time.
    – For some reason when the sublips do reconnect (one at a time) they are converted to 4:3 from anamorphic- so I have to go into Item Properties and manually check off the anamorphic box to make them normal.
    Obviously I can continue with the project, but it will take me a long time to reconnect each sublicip individually and then re-anamorphic (sorry for the made up word) each one manually. It’s going to take a long time.
    Any suggestions?
    Thank you.
    Bouke Vahl replied 15 years, 7 months ago 2 Members · 1 Reply
