Activity Forums Avid Media Composer Reconnecting files through unc path
  • Reconnecting files through unc path
    Posted by Marc Poirier on May 25, 2013 at 5:06 pm
    Hi, i imported a bunch of clips from drive A … to drive B (accidentaly), then i brought drive A home so I can export my work, but a bunch of files are offline (typically quicktimes) … I see that the UNC path is linking to the drive (A) .. but when I select relink, relink by.. choose the more column, all the options are greyed out..
    any way to relink those files?
    thx
    Marc Poirier replied 13 years, 4 months ago 2 Members · 2 Replies
  • Kevin P mcauliffe
    May 27, 2013 at 1:08 pm
    If you have the files, you can simply copy them from one drive’s “Avid MediaFiles” folder to another. Once they are there, and you relaunch, MC/Symphony will rebuild the media databases, and you footage should come back online.
    Kevin P McAuliffe
    Creative COW Leader
    kevinpmcauliffe@gmail.com
    Twitter: @kpmcauliffe
  • Marc Poirier
    May 27, 2013 at 1:24 pm
    Yes, that should be the easiest solution, but that wasn’t working… I was able to reconnect some of them by re-importing the files, then selecting the ones offline and relink. No an easy way to do it, but it was better than re-editing the whole thing!
