Activity Forums Apple Final Cut Pro Legacy reconnecting a razor blade cut
  • reconnecting a razor blade cut
    Posted by Joshua Blankman on July 22, 2008 at 1:41 pm
    I’ve been trying to figure out a way to reconnect two clips that were accidentally cut using the razor blade tool. I thought I used to know a way. I don’t want to nest the clips and it’s too much work to go over every time I cut to go back and redrop the same clip from the master, so is there a shortcut?
    Joshua
    Alex Elkins replied 18 years, 1 month ago 4 Members · 5 Replies
