Activity Forums Apple Final Cut Pro Legacy Reconnect Media…not
  • Reconnect Media…not
    Posted by Enge on July 12, 2007 at 1:59 pm
    Hello,
    I walked into my on-line session this morning to be greeted with a conformed sequence which had been done overnight. All the clips had been captured and were on the relevant drives, but FCP6 indicated that some of the timeline was offline(white timeline). O.K, so I’ll reconnect these clips to the ones that are on the drives.
    Select clip, right click, reconnect media. Up pops the search window, I hit locate, it locates the clip, I say connect…nuthin’. It wouldn’t let me connect back to the clips which were so obviously right, I know this as I’ve just wasted three hours eye-matching…
    Anyone else had this, and if so, how do I fix it?
    Many thanks as always,
    Enge
    Octocore G5
    FCS 2
    5TB X-San over fibre
    Blackmagic extreme
    Jeremy Garchow replied 19 years, 1 month ago 3 Members · 6 Replies
  • Jeremy Garchow
    July 12, 2007 at 2:47 pm
    Are you sure it didn’t connect? Sometimes the thumbnail says it’s offline, but the media is really connected. You can trash the thumbnail cache to update the thumbnails.
    Jeremy
  • David Roth weiss
    July 12, 2007 at 7:07 pm
    [Enge] “All the clips had been captured and were on the relevant drives, but FCP6 indicated that some of the timeline was offline(white timeline). O.K, so I’ll reconnect these clips to the ones that are on the drives.”
    Why did FCP and your media array suffer a disconnect? Clearly that indicates a hardware problem. Your first job in a case like this should never be to fix the symptoms, i.e reconnecting the media, but rather to troubleshoot the source of the problem. Maybe just a reboot of the computer or the raid, maybe more going on than that, but a system working properly should not simply disconnect media.
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Enge
    July 13, 2007 at 9:04 am
    Hi David, I tried a restart of the G5, same thing, I thought it couldn’t be the array as a lot of the clips were online. I have had this once before and was wondering if it’s something that Apple have introduced by way of a bug?
  • Jeremy Garchow
    July 13, 2007 at 2:12 pm
    So you are saying the clips are online, but they show offline thumbnail in the timeline?
    Trash the thumbnail cache.
  • Enge
    July 13, 2007 at 2:14 pm
    And in the canvas/broadcast monitor…
  • Jeremy Garchow
    July 13, 2007 at 2:30 pm
    Got ya.
    Alright, going to start over here.
    You said that the timeline was conformed overnight.
    How’d you conform it, or did someone recapture overnight?
    Jeremy
