Activity › Forums › Apple Final Cut Pro Legacy › reconnect media to different audio tracks
  • reconnect media to different audio tracks
    Posted by Jason Wood on April 16, 2011 at 2:19 pm
    Hi, I’m trying to reconnect media, but i want to reconnect tracks 1&2 in my sequence to tracks 3&4 on the mov im connecting too.
    Basically the orignal mov had stereo on tracks 1&2 and the new media has Dolby E on 1&2 and stereo on 3&4. Tracks 3&4 is the audio i need to reconnect too.
    Is this possible
    Thanx Jason
    Jason Wood replied 15 years, 5 months ago 2 Members · 2 Replies
  • Christina Rodriguez
    April 16, 2011 at 4:37 pm
    When you say “reconnect” do you mean “link”? In this case… If I understand you correctly, then you need to unlink your audio from your video (option-L) then select your new audio and video, and hit option-L again. when you unlink, you will see that your video clip will lose the underline underneath the file name. Once you re-link, the line will re-appear.
    This will link them in FCP, but it won’t replace the original audio in the original video mov. To do this, you’d have to export a movie from FCP.
    C.R.
  • Jason Wood
    April 19, 2011 at 7:02 pm
    Nah, what im trying to do is reconnect a mov to an existing fcp project, but as Dolby E cannot be edited (other than straight cuts) i want to connect tracks 1&2 to tracks 3&4 now. Originally the stereo tracks were on tracks 1&2, but now Dolby E sits in them tracks.
    I can always get them re-ingested with the audio swapped, but trying to avoid that.
    Thanx in advance
    Jason
