Activity Forums DaVinci Resolve Re_Confrom Question
  • Re_Confrom Question
    Posted by Swen Linde on February 19, 2011 at 9:31 pm
    Hello,
    I have little trouble with reconforming after changing the Edit.
    I recently finished my grading job on an 45 min. Series on Davinci.
    It was a great experience. The grading speed is incredible.
    What I did while grading, was adding Versions to get along with white an black levels of the footage,
    of an intercuted “Master Shot”
    So my Master Grading for some Shots isn´t “Default Version” anymore.
    Footage is R3D.
    In meanwhile the editorial changed the edit.
    After reconforming i noticed, that all Grading was automatically set to “Default Grading” Version.
    Is there a possibility to force resolve conforming the Grading Version, which is currently visible?
    Did I miss something, or do i have switch them manually ?
    Thanks for any help.
    Swen Linde
    WeFadeToGrey GmbH, Germany
    Swen Linde replied 15 years, 7 months ago 3 Members · 3 Replies
  • Charlie Edison
    February 20, 2011 at 12:10 am
    The default version is set after a re-conform, you’ll need to go through and select other versions as required.
  • Gabriele Turchi
    February 20, 2011 at 11:08 am
    mmm…that is not handy…
    any way to “make default ” the version currently in use for each shot?
    thanks
    g
  • Swen Linde
    February 20, 2011 at 9:08 pm
    Good question, thanks Gabrielle
    Hopefully someone have a solution.
    Otherwise this should be a request for upcoming Updates.
    Best
    Swen
