Activity › Forums › DaVinci Resolve › Reconforming with grade version intact -A SOLUTION
  • Reconforming with grade version intact -A SOLUTION
    Posted by Michael Stirling on April 3, 2012 at 3:15 pm
    Hi
    I’m bumping this solution to the top as it has just saved me about 4 days work.
    Problem:
    When bringing in a new xml which is a reconform of a current timeline any clips that have multiple grade versions will default to version 1 rather than the current version you are using.
    Solution:
    In the Color Page of the old conform right click in the timeline and select Batch Copy
    In the Color Page of the reconform right click in the timeline and select Batch Unlink then Batch Link.
    The grade versions in the reconform should now correspond to your original choices.
    Thanks for this method go to Toby Tomkins
    M
    Michael Stirling replied 14 years, 5 months ago 3 Members · 8 Replies
  • 8 Replies
  • Toby Tomkins
    April 3, 2012 at 3:41 pm
    Remember to duplicate (save as) the project beforehand just in case!
  • Patrick Woodard
    April 3, 2012 at 7:18 pm
    A solution to this issue is at the top of my feature requests. I tried this process and don’t seen to get the results I wanted. Common source clips seem to get the same version number.
    Patrick Woodard
    http://www.patrickwoodard.me
  • Michael Stirling
    April 4, 2012 at 10:10 am
    Hi Patrick,
    You are right – sorry I was over enthusiast and had just applied it too my real world problem of a whole reel of a feature which seemed to look like a solution. As I’m up against it timewise I didn’t stop to test as rigourously as I should.
    After your post I’ve done more testing in a much more simple session and have a better understanding of what happens – the method outlined above will as you say apply the last grade version selected of any given source clip to all instances of that source clip. It is clear why this happens as it is copying the highlighted remote grade, it just isn’t particularly useful.
    M
  • Toby Tomkins
    April 4, 2012 at 10:17 am
    The method still works though as long as you
    Only do step one, to get linking back you can use groups instead. So batch copy the old conform, import new conform and everything should have the correct grade version but alas won’t be linked to the same takes.
  • Michael Stirling
    April 4, 2012 at 11:10 am
    I can’t make that work,
    everything has the last grade of that source clip
    Here’s my test method:
    1 clip cut into 6 parts A,B,C,D,E,F as the conform.
    I create 3 grading versions and apply them like so:
    A1 B2 C3 D1 E2 F3
    The reconform is the same clip edited in a timeline like so A, D, B, E, C, F
    So if the correct grade versions could pass from one session to the other the same grade version would now be next to each other 1, 1, 2, 2, 3, 3
    But the timeline comes in all with grade 1. Any other method of using Batch just gives all with grade 3 as that was the last one applied in the old session.
    M
  • Michael Stirling
    April 4, 2012 at 11:39 am
    Hi
    Here is a workflow that I’ve tested and succeeded on the above test session and another test session with 2 source clips cut into 6 with 3 grading versions each.
    In original project (a copy for safety of course) Batch Copy the session timeline you wish to reconform then Save
    In a new project Load new conform, Batch Unlink then in the Conform page Color Trace from the original Project and Session.
    It’s working so far – going to test some reel world projects now
    M
  • Toby Tomkins
    April 4, 2012 at 11:45 am
    Yup, that’s it! I can’t believe I forgot I used Colortrace! That is indeed the method I used! Sorry! (-;
  • Michael Stirling
    April 4, 2012 at 11:51 am
    No worries Toby – your beer is still safe 😉
    I would have probably given up if you hadn’t have seemed so certain that you done it
    Cheers
    Mike
