Activity › Forums › Apple Final Cut Pro Legacy › recompression problems
Posted by Cee Dee on January 12, 2007 at 6:39 pmi have a project thats over a tb. trying to transcode to dv anamorphic using media manager recompress option. i get the spinning beachball and it freezes after an hour or so. I need to find out if its the same file messing it up. anything else that could cause this? thanks
Shane Ross replied 19 years, 8 months ago 4 Members · 5 Replies -
Debe
January 13, 2007 at 8:09 pmHow much space is available on the drive your are putting the recompressed files on?
debe
Andreas Karoliussen
January 13, 2007 at 11:31 pmHi,
What are your current codec?
Are there any still images or other “odd” material in your project that might corrupt your recompress?Tip is to reorganise your material in FCP bins called
“recomp 1”
“recomp 2”
etc. so that you can recompress a bin at the time, and if you have corrupt/defiant files they wont mess up your whole export.– Media manager ain’t known for stability, if you have defiant files you could try compressor:
highlight your files in the browser ->export using compressor.You could try recompressing to for example photo Jpeg at 20-30% instead of DV
Hope this helps you out,Andreas
Cee Dee
January 15, 2007 at 5:55 pmsince no one is reading this old thread ill just add… another point for avid 🙂
Andreas Karoliussen
January 15, 2007 at 6:33 pmSo edit on Avid then.
Ive been an Avid editor, but edited on FC for 4years now, and was going back to avid for a project. And Ive often said; “this and that is better on Avid”. However after that project i wont mention Avid again…
FC is a great app and if you think otherwise, don -
Shane Ross
January 15, 2007 at 6:46 pm[cls105] “since no one is reading this old thread ill just add… another point for avid :)”
Uhm…two people responded to this thread with questions that you didn’t answer. Very valid questions. If you choose not to answer those questions, then by all means, go back to your Avid.
Many Avid editors, me included, switched to FCP and never looked back…unless we were forced to. But, if you feel FCP isn’t up to the task, and that Avid is, then use the Avid. It is a perfectly fine editing system.
Shane
Littlefrog Post
http://www.lfhd.net
