Activity Forums VEGAS Pro Recompression in DVDA3
  • Recompression in DVDA3
    Posted by G. Knight on August 3, 2005 at 7:01 pm
    Question,
    Why does DVDA3 recompress the video if i rendered it in MainConcept MPEG2, setting “Good”, video quality on “High” inV6? I Burnded a DVD with the recompression and it looked aweful. Thank You for your help Geoffrey.
    G. Knight replied 21 years, 1 month ago 2 Members · 6 Replies
  • Edward Troxel
    August 3, 2005 at 7:53 pm
    As long as the MPEG2 file is DVD compliant and the project type matches that file, DVDA should not recompress it. Use one of the DVDA preset in Vegas then make sure the project type is the same in DVDA.
    Edward Troxel
    JETDV Scripts
  • G. Knight
    August 3, 2005 at 7:59 pm
    As far as i know everything is compliant. is there a way to check if it isn’t?
  • G. Knight
    August 3, 2005 at 8:04 pm
    I’ll try a different preset and see if i get better results. thank you
  • G. Knight
    August 3, 2005 at 8:36 pm
    This doesn’t make sense. I rendered my project again in V6 Mainconcept MPEG2. I assume DVDA3 updates the rendered project from V6 automatically. If not then that might be my problem. However, I opened a new project in DVDA3 and added the same MPEG2 video file as mentioned above. I go to burn it to DVD and IT IS NOT recompressed. I’m confused.
    Also, it seems the “SET IN POINT” is not very accurate. I set the in point at a specific point in the beginning of the video, it plays fine in preview yet when I burn it to DVD The “In Point” starts a few seconds early. Am i doing it wrong or is it a bug? Thank you again, Geoffrey
  • Edward Troxel
    August 3, 2005 at 8:57 pm
    It should not be “a few seconds early”. It should be within 1/2 second.
    Edward Troxel
    JETDV Scripts
  • G. Knight
    August 3, 2005 at 9:16 pm
    I’ve tried it in a few differnet positions and i get the same result. It’s always off a few seconds.
