Activity › Forums › Apple Final Cut Pro Legacy › Recommended speakers/audio monitors
David Roth weiss replied 17 years, 3 months ago 11 Members · 19 Replies
Duffer Schultz
June 14, 2009 at 7:19 pmI’ll echo the endorsement for the KRK Rockit 5s. Bi-amped, so you wouldn’t need additional amplification. Certainly there are better/truer monitors, but the price/performance value of these speakers is pretty great. Plus I’ve had two situations lately where I’ve used them on location for audio reinforcement for small scale presentations
Ron Craig
June 14, 2009 at 10:25 pmThanks again. I followed the lead of all you KRK Rockit 5 aficionados and bought a pair. B&H had only a single one in inventory so they gave me a great deal on it. Got the other from Amazon at $149.
Walter Biscardi
June 14, 2009 at 10:30 pmPersonally I avoid B&H. In the future try Musicansfriend.com if you want to order online.
Hopefully you’ll get a matched set as they now have the generation 2 models out there. hopefully both of your units will be the same version.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Ron Craig
June 14, 2009 at 11:01 pmWhoops… that was a close call. I didn’t even know about that. Doh! But I checked and they’re both G2. Thanks for the heads-up Walter.
Steve Oakley
June 17, 2009 at 5:11 amI’ve always found the KRK’s to be pretty funky and muddy.
you should NOT by speakers without hearing them. in the cheap catagory, I bought several pairs of M-audio MA-5a’s as the cleanest and most neutral sound speakers in the catagory of less then $500/pair. until you listen to speakers side by side with know material ( take a CD with you and listen to dialog and acoustic guitars, maybe piano ) and then you will hear the difference.
for $500 ea, the dynaudio’s blow everything away for accuracy and actually having some natural low end.
I’ve got a set of B&H 5’s that are old, but you can listen to all day long. they don’t lie, or color the sound the way other speakers do. they do need their own amp, but not a big deal.
David Roth weiss
June 17, 2009 at 5:28 am[Steve oakley] “I bought several pairs of M-audio MA-5a’s as the cleanest and most neutral sound speakers in the catagory of less then $500/pair. until you listen to speakers side by side with know material ( take a CD with you and listen to dialog and acoustic guitars, maybe piano ) and then you will hear the difference. “
Agreed!!! M-audio has much greater dynamic range than KRKs.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Ron Craig
June 17, 2009 at 3:10 pmWell, I’ll speak some sacrilege here: I don’t need the best speakers in the world. Yes, I do believe that audio quality is the most ignored aspect of many of the productions that I see. And I do think that good audio adds depth and value to almost any production.
BUT…
Almost everything that I produce is viewed on the web. The speakers those productions play on don’t come close to reproducing what I hear in the studio — through almost ANY decent speakers. And, frankly, my clients almost never mention anything about audio. The audio quality I deliver is far superior to what they seem to be able to appreciate. And, by the same token, some contributors to this discussion board, I’m sure, have a higher level of appreciation for the subtle distinctions in audio than I have. That’s a good thing.
The KRK’s are sounding very good to me.
Duffer Schultz
June 18, 2009 at 3:37 amI agree. While I’d love to have the latest/greatest/best gear of all types, I have to continually balance price and performance, and ultimately the value to the customer. This is probably especially true in the corporate/industrial work where I make most of my money. With all gear, you have to know what it does and doesn’t do, and understand how to get the most from it to be able to deliver what the customer needs.
Would I like to mix on a $1000 pair of monitors (or $2K, or $10)? Of course. Do they sound better than the KRK 5s? Absolutely. But can I do a perfectly credible job for my clients on these $300/pair monitors? Yes.
David Roth weiss
June 18, 2009 at 9:03 am[Duffer Schultz] “Would I like to mix on a $1000 pair of monitors (or $2K, or $10)? Of course. Do they sound better than the KRK 5s? Absolutely. But can I do a perfectly credible job for my clients on these $300/pair monitors? Yes.”
The M-Audio BX5a speakers to which Steve was actually referring sell for only $299.
David Roth Weiss
Director/Editor
