Activity Forums AJA Video Systems Recommended RS-422 Cable?
  • Recommended RS-422 Cable?
    Posted by Nick Lovell on August 27, 2007 at 5:39 pm
    Hey, all!
    I’m looking for an extender cable to go between my Kona LH card and a DigiBeta deck that’s about 20 feet away. I tried hooking together a couple of 9-pin cables I had lying around and it didn’t seem to work. The cables were old, I have no idea if they work, and they certainly weren’t engineered for video device control.
    Is there a specific kind of RS-422 cable that works better than another?
    Also – the cables I find online that say they’re designed for this kind of use are all male-to-male, and the connector on the Kona breakout cable is male too, correct? Is there a specific adapter I should get?
    Thanks!!
    Nick
    Bob Zelin replied 19 years ago 2 Members · 1 Reply
  • Bob Zelin
    August 27, 2007 at 10:21 pm
    you need a generic male to male 9 pin db connector on both ends, with NO SPECIAL WIRING – it’s a generic 9 pin, where pin 1 goes to pin 1, pin 2 to pin 2, pin 9 to pin 9, etc. No null modem cables, no crossing transmit and receive – a simple straight thru cable. You can use a cheapie computer cable, or you can get a fancy one from Markertek – they will all work. This ain’t audio or HD video – RS422 is a simple signal, that will transmit VERY LONG DISTANCES with no issues.
    Go to google, and order a 25′ male to male 9 pin db cable, and you will have no issues. If you are in question of what to get, go to the Markertek site.
    bob Zelin
