Activity Forums Adobe Premiere Pro Recommended preset or transcode?
  • Recommended preset or transcode?
    Posted by Brian Maurer on March 8, 2010 at 2:45 pm
    Working with the new Rebel T2i/500D. It saves to .mov with H.264 encoding. I’m running Premiere Pro CS4 on a Windows machine. I’m wondering if there’s a Premiere preset when starting a new project that’s idea to select for working with the native files. With every preset I choose, when I import the raw files, they have the yellow bar on top, and I have to render them out to begin work. Is there a preset that is ideal, or is it recommended that I transcode the video to some other codec? Thanks for your thoughts!
    Chris Powers replied 16 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Vince Becquiot
    March 8, 2010 at 4:26 pm
    Hi Brian,
    You will not be able to work native with H.264. Depending on your system, (i7 was it?) you may be able to edit just fine without rendering.
    The best alternative would be Quciktime Animation or AVI uncompressed, but you’ll be testing that fast RAID system and it still won’t be native. Then there’s DVCPro HD.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Brian Maurer
    March 8, 2010 at 4:36 pm
    Running a 2.8 quad core, 8GB RAM, 4850 series video card. I’ve not seen too much lag, but I can see it becoming a problem fast.
    I’ve not tried uncompressed AVI, but I can give that a shot. Will that edit easier? And if I do switch over to uncompressed AVI, which preset would I be using in premiere?
    I could convert to dvcpro HD, but I can’t seem to find a video converter that can do it. Media Encoder doesn’t offer it.
  • Vince Becquiot
    March 8, 2010 at 4:45 pm
    Uncompressed will be more reliable, but you’ll need about 3 drives in RAID 0 to play it back.
    The DVCPro HD export can be found under P2 movie.
    Vince Becquiot
    Kaptis Studios
  • Brian Maurer
    March 8, 2010 at 7:07 pm
    Found the P2 setting and was able to run the encode, but it seems that it’ll bring the video down to 720p. Not ideal 🙂 I’ll keep looking for options outside of giving in and just getting a Mac for the ProRes.
  • Vince Becquiot
    March 8, 2010 at 7:11 pm
    You can set the output to 1080P. Choose the 1080i preset and open the advanced video panel, change to progressive.
    Vince Becquiot
    Kaptis Studios
  • Brian Maurer
    March 8, 2010 at 7:20 pm
    Would you recommend that setting over CineForm?
  • Vince Becquiot
    March 8, 2010 at 9:03 pm
    I haven’t worked much with Cineform. I’m sure the results will be comparable, but the workflow will almost certainly beat transcoding to DVC Pro.
    Vince Becquiot
    Kaptis Studios
  • Chris Powers
    March 11, 2010 at 1:21 pm
    I’d like to go back to one of Brian’s earlier questions, the settings for the premiere project. What would be the best settings to choose when editing footage shot on the T2i? Maybe it’s because I’m still running CS3, but I don’t have options (that I can see) to edit full HD. I have HDV (which is a bit different, isn’t it…or perhaps not). This is my first entrance into the world of HD and I’m trying to figure out the ripple effect of changes that are coming as a result.
