Activity Forums VEGAS Pro Recommended Card for Vegas
  • Recommended Card for Vegas
    Posted by Carlo Simone on August 17, 2005 at 2:42 pm
    Is there a recommended capture/video card that works well with Vegas? I am in process of building a new editing machine and this is a key component. Also, is there any other hardware devices that seem to be a necessity for Vegas or simply to make my life easier.
    Thanks.
    Adam Rose esq. replied 21 years, 1 month ago 3 Members · 2 Replies
  • Edward Troxel
    August 17, 2005 at 3:02 pm
    Any standard OHCI compliant card is all you need.
    If you want to convert from analog, you have a few options: Canopus makes a card that has that built-in, Canopus and several other companies make a convertor which will conver the analog to firewire, or you can use a camera or deck for that purpose.
    Edward Troxel
    JETDV Scripts
  • Adam Rose esq.
    August 17, 2005 at 3:04 pm
    I’ll go first
    all you need is firewire for capture – NOTHING else. either a card or built-in port or Canopus ADVC100/110 etc
    if you have a hunky graphics card, it will help for compositing but not much else.
    getting more memory is always a good idea, too
