Activity › Forums › Apple Final Cut Pro Legacy › recommendations RAM & video card
  • recommendations RAM & video card
    Posted by Jim on February 17, 2011 at 3:23 pm
    I’ve been using my tower at home more and more to edit and was running into some performance issue when I have both Motion & FCP (7) open. If I shut down Motion then reopen FCP frame rate goes back to normal (29.97 or 23.97) I seem to recall someone posted a way to clear the RAM cache which would be good to know; but probably more RAM and perhaps a beefier video card might be the ticket.
    Config now: OSX 10.6.4, 2-2.26 GHz Quad Core, 6GB 1066MHz DDR3 and NVidia GeForce GT 120 (VRam 512MB)- RAID 5 4TB eSata.
    As always your sage suggestions would be greatly appreciated.
    Cheers,
    Jim
    Jerry Hofmann replied 15 years, 7 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    February 17, 2011 at 3:29 pm
    More RAM will likely help. If you have Motion open, and you’ve performed a RAM preview, you might have taken up all RAM and disk caching starts… ugly. Get another 6 gigs of RAM and what your experiencing will likely go away.
    Adding a beefier video card is going to make Motion run better for sure. Might check out the reviews of the upgrades available for your Mac at https://www.barefeats.com
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
