Activity › Forums › Compression Techniques › Recommendations For using H.264 for Video Archive
  • Recommendations For using H.264 for Video Archive
    Posted by Jason Salzrulo on April 10, 2009 at 2:11 am
    Hi, I’m a video artist archiving a large catalogue. I’m using CATDV Pro to build the archive and I have compressor to encode (also handbrake).
    The footage I have is mostly DV and I am archiving it as DV when I intend to edit it, but there is a lot of footage from old sources like VHS, I want to keep it simply as reference at comparable quality, but small file size. I’ve tried H.264 encoding for an MPEG4, but often the files seem larger than if I had created an MPEG2. Could someone make some recommendations?
    -J
    Daniel Low replied 17 years, 5 months ago 3 Members · 4 Replies
  • Chris Blair
    April 11, 2009 at 2:26 am
    H264 is a much more efficient codec than MPEG2, so if you compress at the same data rates between the two, the H264 file should look better and the file size should be similar.
    Keep in mind there are a bunch of different ways to encode MPEG2 files as well, from 4:2:0 files compressed below about 9MB/sec for DVD to 4:2:2 MPEG2 compressed at any data rate you want, which is often used for archiving or broadcasting MPEG2 files.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
  • Daniel Low
    April 11, 2009 at 12:31 pm
    What H.264 export settings have you tried?
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
  • Jason Salzrulo
    April 13, 2009 at 4:44 pm
    I have been trying the standard template that comes with compressor.
    I think what would be ideal is if I could set up a decent template in either compressor or handbrake. I’m not used to tweaking the settings within MPEG2 or MPEG4 so I don’t know quite how to wrap my head around it.
    Name: H.264 for iPod video and iPhone 640×480
    Description: H.264 video @ 1500 kbps, progressive, multi-pass. Audio is 44.1 kHz, stereo
    File Extension: m4v
    Estimated file size: 644.17 MB/hour of source
    Device: iPod/iPhone VGA
    Frame sync rate: 5 seconds
    Video Encoder
    Format: QT
    Width and Height: Automatic
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Automatically selected: Off
    Codec Type: H.264
    Multi-pass: On, frame reorder: Off
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 50
    Key frame interval: 120
    Temporal quality: 50
    Min. temporal quality: 50
    Average data rate: 1.5 (Mbps)
    Maximum data rate: 4 (Mbps)
    Audio Encoder
    Format: MPEG4
    Sample Rate: 44.100kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Data rate: 128 Kbps
  • Daniel Low
    April 13, 2009 at 6:52 pm
    If they are just reference files then try dropping the datarate
    Example – Average Datarate 750Kb/s, Max 1500Kb/s, and see how you go – it’s difficult to say without knowing what your footage is like how low you can go.
