Activity › Forums › Blackmagic Design › Recommendations for a capture card/solution
  • Recommendations for a capture card/solution
    Posted by Bcproductions on May 17, 2006 at 11:05 pm
    I was reading a AJA whitepaper on I/O HDV and found it very informative with regards to AJA Kona LH.
    But I am really impressed by the Blackmagic line and I was wondering if anyone could recommend a capture card/solution for inputing Canon HDV to a Mac/ and in doing so explain how he process would work.
    That is, would I Input via component video, SDI, etc. and should I compress the footage? What arte the options, and what are the advantage/disadvantages of each.
    Chris Borjis replied 20 years, 4 months ago 2 Members · 1 Reply
  • Chris Borjis
    May 18, 2006 at 2:35 am
    Not sure if its helpful or not, but HDV does not really need an Input solution.
    I have the jvc hd100u and I capture the HDV footage via firewire.
    I edit, color correct and whatever else, then nest that timeline into an uncompressed 10-bit
    timeline (I have multibridge extreme btw and have done hardware downconversions while capturing the component inputs).
    I never go back to HDV. I only use it for aquisition.
    It works very well on a quad G5 system. I can scrub the timeline as fast as I want anywhere and there is no performance degradation.
