Activity › Forums › Apple Final Cut Pro Legacy › Recommendation on OS 10.4.9, FCP 5.1.4, QT 7.1.5
  • Recommendation on OS 10.4.9, FCP 5.1.4, QT 7.1.5
    Posted by Jeff Coleman on March 24, 2007 at 1:17 am
    I’m trying to edit on my FCP Studio 5.1.1 a project that my client has on his 5.1.4 machine. Unfortunately the project files are not compatible. (I know I can XML import and export, but I don’t want to go that route all through the project.)
    I’m running 10.4.3 and Qt 7.1.2.
    10.4.9 combo update wants at least Qt 7.1.3. Seems Qt 7.1.5 may not be the most stable choice from what little I’ve read. OS 10.4.9 apparently caused someone some problems with FCP and they went back to 10.4.8 to resolve, but don’t have many details there either.
    What’s the consensus? Use XML? 10.4.8? QT 7.1.4??? FCP 5.1.4?
    What’s working for you?
    What didn’t?
    Love,
    Jeff
    Final Cut Studio 5.1, G5 2GHz Dual Processr, 2.5Gb RAM, AJA IO
    Chee Wee wee tan replied 19 years, 6 months ago 5 Members · 4 Replies
  • Gary Morris mcbeath
    March 24, 2007 at 2:05 am
    Jeff,
    I’m using 10.4.8, 7.1.3 and 5.1.4, no problems. HDV and DVCProHD projects, G-5 dual 2.u7, 4 gig ram. Like you, I’m waiting on 10.4.9 or any higher on QT.
    Gary
  • David Roth weiss
    March 24, 2007 at 5:21 am
    Jeff,
    Clone you system drive, then install the update. Why worry???
    DRW
  • Ryan Mance
    March 24, 2007 at 9:30 pm
    I’ve been running Final Cut 5.1.4 with QT 7.1.5 and OSX 10.4.9 without any problems, working on a project between two machines (MacBook Pro and Mac Pro). I’d say go for it.
  • Chee Wee wee tan
    March 25, 2007 at 7:23 pm
    Hi, maybe you should read my post here and give this a try to see if your system is as stable as you thought.
    https://forums.creativecow.net/readpost/8/929634?
    Regards
