Recommendation for RAID Storage?
Hi there,
I’m configuring a new Mac Pro system to replace my old G5. I’m doing a corporate project over the next couple weeks, which has prompted me to make the purchase. I’ll be shooting it on the Sony EX1 in 1080/30p.
I would like to get some advice on what to buy for storage. Ideally, I’d like to buy something for $500-1000, but could possibly go up to $1500 or so if need be (the cheaper the better though). I appreciate for a proper RAID 5 disk array incl. RAID card this is probably pushing it. I suppose it’s just a matter of getting something that would be decent. I will only be using it to do the occasional project. For that reason, I also don’t need a huge amount of storage. I can always backup the project on a cheaper drive once it’s finished and clear the storage for a new project. It would be nice to have a storage solution that could potentially do uncompressed HD; however, that is not essential and I imagine I would be better buying a better storage system (or renting one) for such a project.
I’m in Canada, so my options are somewhat more limited. For that reason I’ll paste some options below, which I’ve found online. Some of these don’t incl. the RAID card. Thanks very much in advance for your thoughts on these or any other suggestions!
Lacie 2tb Biggest Disk Firewire 800 4-Disk RAID – $899
https://www.csctoronto.com/store/product_info.php?products_id=4365Caldigit VR 2tb 2-disk RAID – $919
https://www.csctoronto.com/store/product_info.php?cPath=40_56&products_id=5341Caldigit VR 2tb 2-disk RAID – $649
https://www.csctoronto.com/store/product_info.php?cPath=40_56&products_id=6614G-Technology G-SPEED eS PRO 3TB – $1749
https://www.vistek.ca/store/ProVideoStorageDevices/244357/gtechnology-gspeed-es-pro-3tb.aspxG-Tech G-RAID3 Hard drive array – 2 TB – 2 bays ( SATA-300 ) – 2 x HD 1 TB – FireWire 800, Hi-Speed USB, Serial ATA-300, FireWire 400 (external) $436.96
https://www.ashlin.ca/c.asp?man=Z11848G-Tech G-SPEED eS – Hard drive array – 2 TB – 4 bays ( SATA-300 ) – Serial ATA-300 (external) – $1199
https://www.cdw.ca/shop/products/default.aspx?EDC=1600288G-Tech G-SPEED eS
Hard drive array – 2 TB – 4 bays ( SATA-300 ) – Serial ATA-300 (external) with G-Tech PCIe RAID controller $1,369.80
https://www.ashlin.ca/c.asp?man=Z11848Fusion D400Q (2TB) $1,335.00 (this is US dollars, so would be probably 25% more in Canadian)
https://store1.sonnettech.com/product_info.php?cPath=23_45&products_id=199Mediasonic Pro Raid Box 4-Bay Raid 0/1/3/5/10
2 TB $549, 4 TB $995
