Recommend the Best Additional Firewire Card?
Hello Everyone,
Could you please recommend a good replacement Firewire card to add to a Mac Pro when you use a IoHD?
I foresee needing the extra FW bus to run a FW audio accessory (to provide outputs for Surround Sound monitoring) and for students to run the occasional FW hard drive.
I’ve read in some reviews that the bandwidth needed for ProRes fits fine within the FW400 connection and that the FW800 is overkill.
If this is accurate, does it make sense to connect the IoHD to the New, Additional Bus and leave the original FW bus available for traditional use?
(This is especially attractive, because it would leave the ports on the front of the Mac Pro available and could help to keep students from noodling other connections behind the computer.)
Please recommend if the best action is to connect the IoHD to the Original FW bus or to a New FW PCI card bus; and if connected to a new bus, if it makes a dramatic difference if the card has FW400 or FW800. (I know I could use a 9-pin to 6-pin converter cable.)
Thank you all for your brilliance. Jesus.
