Activity Forums DVD Authoring Recomendations for burning software?
  • Recomendations for burning software?
    Posted by Will Borden on June 21, 2006 at 1:16 pm
    Hello.. I have been using PrimoDVD ver2.0 for burning DVDs on a Pioneer A03 burner.. I now have a couple of Pioneer DVR111D burners and Primo says there are no burners installed??? Is there a way to update PrimoDVD? I can’t seem to find any updates on the net.. I tried to user Roxio Easy CD/DVD Creator to do a copy.. but it throws away the AUDIO_TS folder and this seems to cause the disc to hang in some players and freeze XPPro with windows mediaplayer 10. (works fine if the AUDIO_TS folder is there… Other than PrimoDVD, what would be a good recomendation for burning software? Thanks for the time to read and respond..
    Will Borden <^_^>
    have computer…won’t travel
    https://www.fiberglass-repair.com
    Will Borden replied 20 years, 2 months ago 2 Members · 2 Replies
  • Pierre-luc Pare
    June 21, 2006 at 3:39 pm
    There’s alot of burning software. I use Roxio EMC and never had problems. You could just make a .ISO of your DVD so you’ll be sure you have AUDIO_TS, then burn it with Disc Copier. Nero Burning ROM is great too. For my professionnals needs, I use Gear Software which is very strong.
    Don’t fear the tiger, the Cow is near!
  • Will Borden
    June 22, 2006 at 12:36 pm
    Thanks Pierre-Luc .. I am downloading Gear Video 8 trial now. Thanks again..
    Will Borden <^_^>
