Activity Forums Adobe Premiere Pro Recomend of Graphics card?
  • Recomend of Graphics card?
    Posted by Mark on December 3, 2007 at 4:11 am
    Can anyone recomend a good graphics card for Premiere Pro 2 on XP.
    Is there one that will output the timeline video to a tv monitor?
    Thanks.
    Vince Becquiot replied 18 years, 9 months ago 3 Members · 6 Replies
  • Blast1
    December 3, 2007 at 4:38 am
    SD or HD? for SD you can use a DV video cam that has pass-through or a DV to A/V converter from Adstech or canopus
    https://www.adstech.com
    https://www.canopus.us
  • Mark
    December 3, 2007 at 11:14 am
    Its only SD, Im looking for a low cost solution as we are a small independant school. Maybe the dv to av converter will work .
    Any other ideas/recomendations?
    Thanks again.
  • Vince Becquiot
    December 3, 2007 at 6:31 pm
    For 2 screen solution, and some good hardware acceleration, I would look at the Nvidia 8800.
    If you want to see your preview in a monitor (Broadcast or just a TV), the Canopus ADVC 110 is the one I would recommend (although there is no component output). The video will be sent through firewire.
    Vince
  • Blast1
    December 3, 2007 at 9:19 pm
    The Adstech API-557, PYRO A /V Link, also has component I/O(YPbPr) and is about $65 cheaper, available from Amazon with free shipping.
  • Mark
    December 5, 2007 at 9:42 pm
    Thanks for your advice, We ended up getting the Canopus ADVC 110. We get TV monitor output from After Effects but not Premiere Pro 2? Is there something Im missing here?
  • Vince Becquiot
    December 7, 2007 at 12:39 am
    If you are running them at the same time, that could be your problem. They would both try to use the hardware at the same time.
    If not, have you set your Premiere playback settings to External: IEEE 1394 ?
    Vince
