Activity Forums Zaxwerks Recognizing correct shape
  • Recognizing correct shape
    Posted by Jennifer Hoge on October 26, 2007 at 1:44 am
    I am trying to get ProAnimator to recognize a certain portion of a logo. There is a black arc with a circle sitting directly on top of the arc, right in the center. The circle has a white outline that creates the illusion that, with the arc below it, it looks like a person with arms out (head and arms). Looking at the graphic, it would appear there was a ‘hole’ around the circle that would appear transparent. The path is just an arc and a circle, so ProAnimator is not recognizing the ‘hole’ or the outside edge of each ‘arm’.
    I have no idea how to prep that piece in Illustrator so ProAnimator can recognize the correct look. Can someone please help!
    edit: I can get the circle in with a beveled edge that works ok for me, if I can figure out how to get it to recognize the outside edges of the arc (it’s thick, so it’s not just a line)
    (Is there a way to attach or upload just that piece on to this site so I can show you what I’m talking about)
    Jen
    Steven Wills replied 18 years, 9 months ago 3 Members · 6 Replies
  • Jon Okerstrom
    October 26, 2007 at 2:50 am
    Hi Jen,
    Learn how to embed images here:
    https://library.creativecow.net/articles/lindeboom_kathlyn/whipped_cream.php
    Looking forward to your images.
    Jon
  • Jennifer Hoge
    October 26, 2007 at 3:04 am
    Here is the look within the logo that is being misinterpreted:
    Logo black center
    Here is how it looks when I bring it in to ProAnimator:
    Proanimator interpretation
    I am currently using the paths that were set up by the designer of the logo, but I do have the Illustrator file to make the changes necessary for ProAnimator.
    Thanks in advance for any advice you can give me.
    Jen
  • Jon Okerstrom
    October 26, 2007 at 3:24 am
    Hi Jen,
    The picture is worth a thousand words. I suspect there is a white shape not visible in your top image because the background is also white. If you want, send the file to me and I’ll take a look.
    jokerstrom1 (at) mac.com
    Jon
  • Jennifer Hoge
    October 26, 2007 at 3:33 am
    Thanks, Jon. I just sent you an email!
  • Jon Okerstrom
    October 26, 2007 at 4:02 am
    For people following this thread – Jen sent me the file. The issue was that the arch was a line with a thick stroke rather than a filled solid. ProAnimator considered the line to be an open path and closed the path, resulting in the odd shape.
    The solution involved expanding the object so it became a filled solid, then using pathfinder to make separate left and right arches and the oval in the middle.
    Jon
  • Steven Wills
    November 5, 2007 at 3:09 pm
    Very helpful.
    Thanks for the followup.
    Steve Wills
    Dual 2.5 G5
    FCP HD, Motion
