Recessing Brick Animation
I’m working on an animation where bricks move backwards randomly to a specific point in the wall. Then a second layer of bricks will move back. See attached animation for first layer moving.
The problem is that do get nice shadows I have to set the shadow map resolution of my comp to 4000. When doing this, I get RAM errors when rendering out my animation at 1080p.
The bricks are all made in a precomp where 5 jpeg sides are arranged to form a brick. No back wall, as we never see it. They all those precomps are put in a master comp with collapse transformations and then arranged to make the wall.
So my questions are as follows?
1. Is there an easier or more automated way of doing this? Perhaps with a script or something similar?
2. If not, does anyone have any tips to make this less heavy on the rendering/RAM/processing? Basically, make the setup more efficient.I am using an i7 iMac with 16gb of RAM with AE CC on Mavericks.
Thanks so much!
Ari
