Activity › Forums › Apple Final Cut Pro Legacy › Receiving “Not Found” – then “Error:Out of Memory” trying to open Sequence
  • Receiving “Not Found” – then “Error:Out of Memory” trying to open Sequence
    Posted by Jason Watt on March 11, 2011 at 1:27 am
    I have received a FCP Project edited in 2009 from the UK and have pulled the project file onto my workstation and all of the media onto an ext HD. I have also reconnected all of the media. However, when I try and open one of the Sequences in the project – I receive the following error “Not Found” then once I click off of that a second error “Error:Out of Memory”. All of the other sequence in the project open fine.
    Initially, I was able to open the original project file and open the sequence – but when I tried to copy the sequence & paste into a new project-I would receive the errors. Now I am receiving the same errors in the original project.
    At first I thought it might be an problem with the computer but I have tried this on two different work stations /computers so I don’t think it would be a prefs ( trash preferences) issue. Also footage was first on an XRAID and then I brought it to an external HD, so I don’t think it had anything to do with permission issues.
    This sequence is critical that I am able to get to it as it is part of a TV episode, so I would very much appreciate any help / advice on fixing this problem ASAP!
    Jeff Greenberg replied 15 years, 6 months ago 2 Members · 1 Reply
