Activity Forums Panasonic Cameras Received New HVX200 – Observations for JLC
  • Received New HVX200 – Observations for JLC
    Posted by Brian FitzGerald on February 11, 2006 at 4:54 pm
    I got mine a couple of days ago but have been busy shooting and editing a couple of projects with my old cam and had scant time to work with the new cam.
    Overall I like the camera a lot. I was able to download some files to my G5 Final Cut without even reading the manual. They looked good. I can see this camera will improve my commercial output for sure.
    A couple of dislikes:
    The apparent size of the monitor in the eyepiece is disappointingly small. I have been using a Sony DSR250 for some years now and it has a much larger viewing angle/area. The 200 eyepiece monitor seems like it is “farther away”, swimming in the vast darkness of outerspace…
    One other thing. I tried shooting a few different formats for fun and then find I cannot view them back in the LCD monitor unless the playback is set the same as the recording was – or something like that. So far I haven’t found a quick method for changing this but regardless, I really think this should be done “on the fly” by the camera itself.
    Also, I really wish the focus ring was “direct” instead of floating. At least the zoom is – and that is a real PLUS.
    The manual really suffers from a lack of an alphabetical index in the back. That is one of the best ways to find things fast. Also, it tends to use letter abreviations instead of whole words TOO MUCH. After a while I’m sure I’ll recognize them but at first it is very trying… A standard convention is to first use a term (maybe in boldface) and then append the initials or shortform. Like: …when you are inserting a Digital Video (DV) tape…
    A short glossary would be useful in this regard.
    Daniel E replied 20 years, 6 months ago 3 Members · 4 Replies
  • Brian FitzGerald
    February 12, 2006 at 9:13 pm
    As a followup to my previous post, here are some of the abbreviations I haven’t been able to figure out yet:
    MCR
    OSD
    SW MODE
    MIKE ALC
    TCG
    UB MODE
    UB PRESET
    EOS
  • Jan Crittenden livingston
    February 12, 2006 at 10:18 pm
    Brian FitzGerald:As a followup to my previous post, here are some of the abbreviations I haven’t been able to figure out yet:
    MCR Memory card recorder
    OSD On Screen Display
    SW MODE Switch Mode
    MIKE ALC Not sure about it called MIKE, but MIC ALC would be Mic Auto Limiter Control
    TCG Time Code Generate
    UB MODE User Bits Mode, which mode do you want it to operate in
    UB PRESET If you want User Bits to start at a Preset number
    EOS Boy you have me there. I have looked through the manual, and at virtually every menu and I don’t find this abbreviation. Do you mean OIS, if so then that is Optical Image Stabilization.
    Hope this helps,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Brian FitzGerald
    February 13, 2006 at 12:56 am
    Thank you very much for your reply. It was very helpful.
    I believe I saw “EOS” at the end of a clip playback but I haven’t been able to replicate it tonight.
    I’m starting to get the hang of this cam but it will take a little while. It is very complex and that is good.
    I’m still wondering if you think these two observations have any merit for your engineering staff:
    1. The apparent size of the monitor in the eyepiece is disappointingly small. I have been using a Sony DSR250 for some years now and it has a much larger viewing angle/area. The HVX200 eyepiece monitor seems like it is “farther away”, swimming in the vast darkness of outerspace…
    2. One other thing. I tried shooting a few different formats on the same p2 for fun and then find I cannot view them back in the LCD monitor unless the playback is set the same as the recording was. So far I haven’t found a quick method for changing this but regardless, I really think this should be done “on the fly” by the camera itself.
  • Daniel E
    February 17, 2006 at 3:42 am
    Could EOS be end of Scene?
    Daniel Epstein
    Gold Teleproductions, Inc
    New York, NY
    http://www.goldtele.com
