Activity Forums Adobe Premiere Pro Recapture Some sources on the timeline
  • Recapture Some sources on the timeline
    Posted by Alex Udell on September 8, 2009 at 8:33 pm
    Hi All…
    CS3:
    We’re just wrapping a project with a mix of soure materia.
    Some file based (which is working fine)
    some tape based.
    Now I want to go back and recapture just the tape based source at online resolution, but only frames (plus handles) used in the sequence.
    I’ve created a duplicate project,
    eliminated all but the sources I wanted from the project panel leaving only the sources I need to batch on the timeline.
    Now I have passed this reduced project thru Project Manager/trimmer, with “make offline” enabled.
    But I can’t seem to generate new clips representing only what is used on the timeline for recapture.
    What am I doing wrong?
    Alex
    Alex Udell replied 17 years ago 2 Members · 2 Replies
  • Eric Jurgenson
    September 10, 2009 at 4:19 pm
    Hi, Alex,
    This is a guess (because I’ve never tried it), but I’m thinking Premiere might have a problem trimming HDV clips (due to the long GOP file structure). Are you recapturing HDV?
  • Alex Udell
    September 10, 2009 at 5:31 pm
    Hi Eric…
    The issue is that original source was captured as full continuous reels.
    Now I want to capture just the frames used on the timeline.
    But I can’t seem to get PPro to actually make the new clip entries via trimmer for the recap.
    Seems like the above method should do it, but I just end up with a copy of the project with the same remaining master clips in it.
    Alex
