Activity Forums Apple Final Cut Pro Legacy Recapture question.
  • Recapture question.
    Posted by Håvard on November 17, 2005 at 10:18 am
    Hi there good people of the cow!
    This is probably just me having had too much coffee or something, But:
    I need to recapture some footage that was captured with one mono channel of audio (which is no good since the interviewer is on the other mic, I taught my boss a quick lesson afterwards..). What do I do to recapture (I have made it offline) with both audio channels, preferably in mono. There is a tab in the log and capture window which says “use digitizers default settings” which is grayed out and I just dont get it.
    Any help would be much appreciated.
    G5
    Final Cut Pro 5.03
    Håvard replied 20 years, 10 months ago 2 Members · 4 Replies
  • Bouncing Account needs new email address
    November 17, 2005 at 11:52 am
    Here are the steps (including the first ones, which you have already done.)
    In the bin, Select (highlight) all of your (incorrect) clips.
    Then, Control-Click (and HOLD the mouse button down) on one of them and choose: “Make Offline…”
    Next pop-up window, choose “Delete from Disk” > OK > OK.
    Locate the “Tracks” column in the Browser.
    Now, make sure that all of your (formerly incorrect) clips are still Selected (highlighted) and…
    Then, (in the Tracks column) Control-Click (and HOLD the mouse button down)
    on one of the clips and choose: “1V 2A” (1 Video Track, 2 Audio Tracks).
    All of the clips should now show this new setting.
    Batch Capture.
  • Håvard
    November 17, 2005 at 12:12 pm
    Thanks for the reply, but this is exactly what is weird. When I go to item properties I cant change anything but anamorphic and alpha level. And when I right click in the tracks column of the browse (and the clip is offline and highlighted)I get the message “no shortcuts”. Hmmm.. Ive been through all the menus and settings and stuff and I cant find any relevant settings. My settings are correct in the clip settings part of log and capture but fcp seems to only follow the original digitized settings. I also tried exporting the clip to another project but the result was the same..
    November 17, 2005 at 4:14 pm
    You need to Make the clips “Offline” AND “remove” them from the disk.
    If it still doesn’t work after that:
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Håvard
    November 18, 2005 at 8:07 am
    Thanks for all of your tips Matte. I just discovered that all I had to do was to switch of the “use logged clip settings” tab in the batch capture window.
    Doh.
