Activity Forums Apple Final Cut Pro Legacy Recapture online from Offline RT from captured DV footage on FW Hard drive instead of the DV Tapes?
  • Recapture online from Offline RT from captured DV footage on FW Hard drive instead of the DV Tapes?
    Posted by Mario Rodriguez on June 16, 2005 at 2:08 pm
    I don’t know if this question was asked before, and I guess is not possible.
    imagine you have captured 20 hours of DV in full resolution to en External FW Hard drive, which would be something like 260GBs or so. Ok you want to take that on your powerbook with you for editing. So you use Media Manager en Recompress everything to a new project to Offline RT. You make a rough edit on your powerbook and then you want to recapture the sequence online.
    You still have those 260GBs with the DV captured in full resolution on you FW hard drive. Is it possible to recapture the Offline RT Sequence from the FW Hard drive or must be always recaptured from the original DV Tapes?
    Mario Rodriguez replied 21 years, 2 months ago 3 Members · 3 Replies
  • Gunner Jones
    June 16, 2005 at 5:53 pm
    If I am understanding you correctly, you don’t have to recapture. Just make a new offline sequence for DV using the media manager and then re-link to the original files.
    O&O-Gunner Productions
    FCP-Avid-After Effects
  • Andrew G.
    June 16, 2005 at 5:56 pm
    Mario,
    There’s a whole article on offline-online procedures at wwww.kenstone.net.
    Anyway, here’s what I’d do, assuming your using FCP 4 or later:
    1. In your offline project, highlight all of your footage clips and sequences in the Browser.
    2. Ctrl-click the selection and choose “Create Offline”
    3. In the Media Manager window, select “Create Offline” and choose the online resolution you would like the selected clips to use (i.e. NTSC DV)
    4. Select the checkbox at the bottom to create a new project, which will contain the new clips and sequences, and hit OK. Name the new project.
    5. FCP will automatically open the new project. In the Browser, you will notice that all of the footage clips are now offline(not offline rez, but offline “missing”). Select all your clips and sequences once again.
    6. Ctrl-click the selection and choose “Reconnect Media”
    7. Make sure your FW drive is plugged in and Browse for the first clip that FCP looks for. You are now looking for the DV-rez version of that clip. Also make sure that “Reconnect all files in relative path” is checked, so you won’t have to reconnect for every single clip in the same folder.
    That should do it. I’m not in front of my desktop right now, so forgive me if some terms are a bit vague.
    Andrew
  • Mario Rodriguez
    June 16, 2005 at 7:14 pm
    Fantastico!!!!
    Thank you guys, you’ve been a big help….
    Mario
